It is currently Mon Aug 11, 2025 3:25 am
PostPosted: Wed Oct 21, 2009 10:38 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
My restoration of the old guitar is moving along. Top removed ...new top cut and ready for install and old Fingerboard needed a little work. I chose to try to redo the original fretboad because of its unique beauty. String wear indentions between frets made me pull the frets and I re planed the fret surface down just enough to rid the indentions. There are still fret slots, so I only need to resaw slightly deeper to reinstall new frets. I would like to use a black/maple thin laminate between the fret board and the neck to raise the fret board back to its original height. This would also give me an edge detail that would match my new black/maple laminate peghead redo.
Does anyone ever glue fretboards on necks using wood laminates in between? Any problems or strength issues doing this? I assume you need to glue the laminates to the fretboard first, trim/scrape to fretboard edges and then glue to the neck? This way you only have minor basic glue cleanup on the top.
Kent Bailey
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Wed Oct 21, 2009 11:58 am
No reason that wouldn't work fine.
PostPosted: Wed Oct 21, 2009 12:13 pm
I've done the same thing often.... No problem.
PostPosted: Wed Oct 21, 2009 1:37 pm
I'd stay away from glue with water in it though. You can get some serious cupping.
http://www.chassonguitars.com
PostPosted: Wed Oct 21, 2009 1:40 pm
epoxy :D
Users browsing this forum: Colin North and 15 guests
